Water pipe flow rate for drainage ditch
1 Jul 2014
Durham
Hello
Can anyone help me with the calculation for maximum flow rate for a 300mm that will be used as a culvert to convert an open water course into this piped culvert.
I expect that the pipe will only be half full.
The fall is 1 in 100 and I need the result in litres/second to comply with our councils drainage engineers request.
Thanks in advance
I searched Google and found this:
http://www.brighthubengineering.com...te-water-flow-rates-for-different-pipe-sizes/
so the sum is:
Q=0.278x100x0.3^2.63x(1/100)^0.54
where 100 is for a concrete pipe, 0.3 is the diameter in metres and (1/100) is the fall.
I get an answer of Q=0.09747m^3/S or 97.47 litres/second
That would give you a velocity in the pipe of about 1.4m/s (or 3 mph) which feels about right.
I have no idea if I am right about this - I'm an alarm engineer! :LOL: The sums look good and, if you mention the Hazen Williams formula, I'm sure that the council engineer will think that you know what you're talking about! ;) [/b]
