Following a leak, Dynoplumb visited our house and replaced the metal mains service water pipe to our house with a new blue plastic pipe (25mm) from the road to the front of the garage, then reduced this sized pipe to 15mm - approx. 9m under the garage before connecting to the internal stop cock. However, the main tank in the loft now runs dry and this did not happen prior to this work.
Should Dynoplumb have continued with the wider 25mm pipe and not reduced it to 15mm - Dynoplumb are now stating it is Affinity Water's issue, and Affinity Water are now blaming Dynoplumb - so need a little advice please?
Many thanks
Many thanks
