Water Pipes 15mm 22mm?
26 Apr 2011
Leicester
Hi there, I have a terrace house with a combi boiler downstairs. Im refitting my bathroom. I have looked and seems like i have 15mm feeds both hot and cold coming from my boiler into my bathroom.
I want to install a mains powered shower. I have alot of 22mm and 15mm pushfit pipes and bits. I just dont know what to do for the best.
As a rule ive herd you use 22mm for hot and 15mm for cold?
If i run 22mm hot to my shower would there be any point when i have the hot in 15mm directly from the boiler, would there be any gain?
Any help would be great , cheers
With your combi, I would say 15mm is fine to supply a shower.
A thermostatic mixer shower is best suited for combi's
Al
Reading between the lines, you want to fit an electric shower. If you are set on one of these, then a 15mm cold feed is fine.
However, if your combi produces a reliable flow of hot water, then I recommend you forget electric and put a thermostatic bar mixer in, fed from your hot and cold.
I dislike electric showers, and unless you go for the most powerful (and expensive to run!), then the flow is often pathetic.
Then there's the high cost of fitting electric. A decent shower will be £200, plus the same again for an electrician to run a heavy cable from consumer unit, including switches and MCB.
Do yourself a favour
http://www.plumbworld.co.uk/mira-co...gleBase&utm_medium=GB&utm_campaign=GoogleBase
