The water supply to my house feeds several properties (4 houses, 11 beds total) locally, all from (i think) a 1" (32mm?) supply which travels 500m from the meter before splitting to each property. Water pressure at the meter is approx 4 bar.
As you can imagine, if two upstairs showers are used in the house at a time, or other properties are using water also, the supply tends to struggle a big. This is especially true given my house is higher up than the other properties supplied.
Is there anything I can do to boost the water flow rate? I'm thinking that the supply pipe should really be significantly bigger than 32mm to feed all properties. I'd rather not try and tackle this yet....but out of interest, what size pipe would be recommeded for such a supply please?
TIA
TIA
