- Joined
- 30 Dec 2003
- Messages
- 10
- Reaction score
- 0
- Country
I am not happy with the peak hour pressure of my local water supply in East London.
I've found booster pumps on the web, but wanted to understand how they work, and how effective they are in real life.
Is the following correct?
There is a storage tank filled from the mains, a pump and a pressure vessel. As the water is drawn from the tap, the pressure in the vessel drops. When the pressure drops to a preset value the pump turns on and increases the pressure to the set limit. The amount of water you draw before the pump fires depends on the pressure and size of the vessel.
Questions (assuming the booster is for the supply for the whole house)...
How noisy are they? (I will install it in the garage, and do not want to hear it in the house).
Are they significantly expensive to run?
What maintenance is required?
Other than purchase price and the space required, are there any factors against an "over specced" size of pressure vessel?
What is a generous flow rate/pressure required for a 5 bed house (ground floor, first floor and loft extension)?
Any issues with having the storage tank underground?
Thanks!
Thanks!
