Water pressure problem
7 Dec 2007
Birmingham
Hi guys,
Please help!
I have a combi boiler with around 10 rads. the central heating system works fine. My issue is with the hot water. When opening the hot water downstairs, i get no hot water upstairs. However, when opening the cold water downstairs, i am still able to get cold water upstars.
Please advise! Many thanks
Welcome to combi boilers! :LOL:
It is quite normal for the hot water to behave this way as it will take the easiest route.
Cold water will be unaffected as it is under mains pressure. :D
is there no solution then? a water pump maybe?
You cannot pump hot water from a combi.
Only use one hot water outlet at a time. ;)
You could, of course, fit a high flow rate combi - but I expect this isn't the sort of answer the OP was hoping for.
