I've just had my first combi boiler installed, always had gravity before, so have to come to grips with a different way of operating. Particularly with the DHW.
My first question.. Now that the hot water is mains powered, should the flow rate at the hot bath tap be identical to the cold tap, or does going through the heat exchanger in the boiler reduce it a lot? My cold water comes out very very fast and quick, the hot water not as much.
Also noticed the flow rate from the hot water tap seems to vary at different times of the day, is this now down to being mains powered and the mains supply can be lower pressure in the mornings when everyone is using it, or is the boiler being clever and altering the flow itself based on incoming water temperature to reach the desired setting?
