Water Pressure to Undersink Water Heater
24 Jan 2020
Malta
Hi All,
I have an Ariston under sink water heater installed in my kitchen. It is fed by a water supply from a water tank on my roof via an electric pump which switches on when it senses water flow ( at least I believe this is how the pump operates ).
A safety valve came with the heater and has recently started to leak from the nipple.
I replaced the valve for a new one which also started to leak, albeit very slowly, again from the nipple. I understand this to be normal but I need to deal with the leakage.
https://allaristonspares.co.uk/Ariston-Safety-Valve-1-2-2-Bar-411379-Eureka
I then purchased a pressure regulator as I was told that I may have too much pressure.
I attached this and set the pressure for 2 bar. This seemed to work fine when the hot water sink tap was open but once closed, the pressure on the regulator rises to 8/9 bar. Should this be of concern?
valvula-reductora-de-presion-a-piston-rinoxdos
https://www.genebre.es/valvula-reductora-de-presion-a-piston-rinoxdos
The Ariston heater states 8 bar on a label fixed to it. I don't know if this is max pressure, suggested pressure or otherwise.
Do I need both a safety valve AND a pressure regulator fitted to the inlet connection of my water heater?
Can I connect a pipe from the nipple of the safety valve to my sinks drainage to deal with whatever leaks occur ?
Many thanks in advance for any helpful advice, suggestions or education!
Nicholas
Malta
