Water Pump
21 Aug 2013
Sheffield
We have recently had a new bathroom fitted, however the sink and bath taps fitted seemed to have reduced the flow and pressure from our gravity fed hot water system.
I've been looking at different solutions to increase the pressure including replacing the vented cylinder with an un-vented one. However the easiest solution looks to be to fit a water pump.
I'd like the pump to go on the hot water outlet just after the cylinder, the pipe only feeds a hot water basin tap, bath tap and a sink tap downstairs (however this is fine due to the distance from the header tank).
My quest is can anyone suggest a pump that i can uses to do the job?
Many thanks,
Hi Andy,
If is just to pump the hot water to the 2 bathroom taps and kitchen hot water tap another it's not needed for this one.
Thanks.
