- Joined
- 3 Jun 2016
- Messages
- 134
- Reaction score
- 3
- Country
Hi I've recently had a new extension built and some changes to my kitchen. As part of the work a new Worcester Bosch CDI combi boiler was fitted to replace the old one and a three new vertical rads were fitted.
I've been trying to get to the bottom of why two rads in particular make a lot of water rushing noises. I've bleed the system twice, got rid of all the air, balanced the system ..... but still two rads in particular make a fairly loud water rushing sounds as though there is a lot of pressure going through them. These rads are in the hallway (very loud) and in the lounge next to the TV. They are a couple of the older rads. Being a combi I have noticed that the sound goes up and down depending on the stage the boiler is at in the heating cycle (! not sure what its called). It almost sounds like the water is running at too much pressure if you know what I mean.
If I turn the lock stops off the sounds goes away, well I say away you can still hear fairly quietly the water running through the pipes but that's not too bad. If I open the locks then the noise increases the more they are opened. The problem is if I open them so I just get an acceptable amount of sound there rads don't warm enough.
Friends have also commented that they seem loud so I know it's just not me an OCD.
Any idea's at all ? Maybe bad lockstops, thermostats on the rads, air still in there that bleeding the rads isn't releasing. I'm basically out of ideas.
Steve
Steve
