I know this subject has been covered before but I am trying to find a solution.
I have a new-ish house with a Megaflow and an Ideal Condensing boiler. The water quality in our area very hard and I would like to fit a water softener e.g. Kinetico 2020c Hi-Flow. However, a big label on the boiler states that softened water should not be used.
In the loft is a small header tank for topping up the heating circuit. It's almost impossible to run a separate feed from the rising main to this tank.
So, is the preferred solution to turn off the header tank and keep checking regularly, topping up with a jug/garden hose?
Alternatively, assuming no leaks in the heating system, how much water is taken from the header tank? Over time, will the water in the system gradually be replaced with softened water i.e. potentially damaging the boiler? Doesn't the inhibitor (Fernox) prevent any corrosion problems?
Obviously, if we ever drained the heating system, the header tank could be refilled from the garden hose or by using the softener bypass facility.
Thanks for any advice.
