Water softener feeds
23 Jun 2013
Hi there
I've been trying to wrap my head around a particular problem and decided it's time to ask some experts.
I've just bought a water softener which came with a 22mm connection kit. All of the piping in my house is 15mm. I don't seem to be able to buy 15mm inlet connectors for the back of the softener so I guess I'm left with 1 option. Using a 15mm to 22mm adaptor.
My question is, will there be any adverse effects by up converting from 15mm to 22mm on the softener? I'm assuming that there will be a pressure drop but I don't know if this will be a problem or if there is any other side effects.
Thanks in advance.
Should be fine, pressure will be the same on 15mm pipe, just the flow rate will be lower.
Excellent thanks Denso. Looking at It the bypass kit comes with a 15mm reducer anyway so it's entirely possible to go from 15mm to 22mm using the manufacturers supplied fittings.
