I live in an upstairs flat. A pipe burst fully inside of the space of the flat below just below the ceiling. The supply to the flat below tees off immediately after a stopcock under my floorboards. If I turn the stopcock off, its turns off supply to both flats. My question is: who is responsible for the burst pipe, me or the owner of the flat downstairs? I own the leasehold of the flat below.
The owner of the flat below insists that I am responsible because I ultimately supply his water. I insist that it is not my problem because the responsibility for pipework from his flat leading up to my stopcock is technically his, even if part of his supply pipe and the stopcock is under my floorboards. I.e, my responsibility ends at the point where his water tees off. Who's right...?
We've both had our water supplys cut off for two days now to prevent further damage while we argue over whos going to repair the pipe. Please help!
Thank you.
Thank you.
