Hi all,
I am on the ground floor of a house divided into three flats.
Need to turn off the water to replace the bath tap.
Can't find a stopcock in the house to turn off the water in the bathroom.
The only one i have found (under the kitchen sink)
cuts the water to the combi boiler.
I will most likely turn off the water from the main supply outside.
Without bugging my upstairs loft dwelling neighbor are there any tell tale signs that would indicate whether or not there is a cold water tank in the loft?
would i be causing any danger by shutting off the water outside for the duration of the job?
please advise!
thanks
please advise!
thanks
