Hi all. I want to replace old bath taps. I have a stop cock under the sink and a oil combi boiler which pumps the hot water upstairs on demand, to stop all water, do I just turn off the stop cock and switch the electric supply to the boiler off.
If there are no isolation valves under your bath then yes that is all you need to do. also turn your kithcen taps on to drain the water, it would be an idea to fit isolation valves while you have the chance aswell.
