Help !
Yesterday I turned off the mains to change tap washer in kitchen - ok
Today - no hot water ! In loft, the tank which feeds hot water cylinder is empty down to the outlet pipe.
The ballcock seems to move freely and no reason to suspect it is not working.
I have just tried a very quick turning off of mains, turning on taps etc trying to move air lock. Need to do it properly when I come back from work.
Any ideas other than the usual air lock cure of carefully opening taps from the bottom ? Why should the cold water be fine from all taps down and upstairs - but not reach the loft ??
Any advice would be appreciated
