Hi - have had a problem now with the cold water tank that feeds the hot water cylinder over flowing outside our house.
This first happened on boxing day and strangely happened overnight when no heating or hot water was switched on.
As the cold water tank was old - (and it later became apparent the over flow blocked) this emptied over my dining room.
So - believing that it was a hole in the old cold water tank, we had this replaced.
About a week later again overnight and again with no hot water or heating switched on (gas fired boiler system) same thing happened. This time plumber came out and believed it was a faulty thermostat on the hot water cylinder boiler so changed it and put a new overflow pipe outside the house - at least now stopping more water coming into my dining room.
All well for 3 weeks - then last week trickles of water from the over flow outside the house - again over night and again no hot water or heating switched on.
On investigation the pipe that takes the cold water from the cold water tank to the hot water cylinder was warm - at the cold water tank in the loft. More so the water in the cold water tank was warm.
Drained system and problem stopped. A week passes by then happens again.
Called plumber and he now seems to think it is to do with the cold water pressure pushing back through the system.
The hot water pressure is so low in our house there is a pump to push the water through when the hot taps are turned to draw.
He believes that the problem could be happening at a mixer tap and somewhere the cold water pressure is pushing the water back through the whole system.
Whilst I trust his judgement - I was wondering if anyone else has any views on what the problem could be?
He is coming to fit a pressure reducing valve this week so fingers crossed...
Sorry for long thread, but as you can see we've already changed a lot of things on our system and we're fast running out of cash...
Would really appreciate some views on this..
