Water test strips
5 Jan 2003
Essex
If I took a water sample from the hot tap for testing for water quality,can you get a water test strips for testing descalers and inhibitor chemicals as to find out if the coil is leaking inside the cylinder ? Sometime if you have a tiny leak you wouldn't noticed if the level of the cold water storage tank dip level is dropping,just wondering if this is another way of finding out.
Yes you can but I think te sample would be too diluted to see the chemical. What makes you think you may have a problem?
