Hi all,
I know this is a fairly common topic but I wanted to discuss the specifics of my case.
We get 2-3 inches of water under our floorboards at the front of our house after heavy rain. All the drainage has been checked and, while we did find a few problems, these have now been rectified and the problem has not gone away.
The void is very deep at this point, considerably deeper than ground level, and we have a poor block paved drive at the front. The drive has no drainage and when I sprinkle drain dye over the paving at the front when it rains, the dye appears about 12 hours later in the void.
The drive is awful and needs relaying with proper drainage which I am planning to do but I'm concerned this wont fix the problem as the water appears to be coming in through the walls at the bottom of the void. Would we need a french drain as well and is it worth considering filling the void up to 200mm to raise the ground level so that the water does not drain into it. There is no concrete oversite in there at the moment its just earth. We are on heavy clay soil. I know there is the option of a sump pump but i'd rather stop the water coming in and also I'd like t0 lay a new floor which would be difficult with a sump pump and we would need access to it.
