I have had a problem since my new system was installed. The house was completely re-plumbed. I have an Unvented System, with Worcester Bosch boiler and Megaflow Tank. I have a new mains supply over a 32mm pipe.
The Tank and Boiler are in the loft, about 8 metres above the stopcock.
I have a Bronze pump for the hot water supply around the house. The hot water system works fine with no problem.
I have a water softener and can easily bypass the water softener, which I have done to try and understand the problem.
The garden taps and kitchen tap are on the hard water supply. The water company are supplying me 2.5 bar and circa 15 litres per minute.
The Megaflow tank has balancing valves on it which I am told is to ensure that the Megaflow is not supplied with more than 3 bar (!).
Now for the problem which no one seems to be able to solve. When I run one cold water tap on the soft water side of the system (Water softener in circuit or bypassed) the flow rate is fine, although 9-10 litres per minute, but as soon as I open a second outlet or run a toilet the flow of water almost disappears.
The standing pressure at the Megaflow Tank is 2.5 Bar, which seems pretty good compared to the mains, but as soon as I open a cold water on the soft water side of the system the standing pressure drops to > 0.5 bar.
Any help appreciated. Ken
