Half of my garden is flagged, the other half turfed. The problem is the slabs are always covered in about an inch of water and my turf is always waterlogged. I know there is a natural spring that runs the whole width of the garden towards the rear. Also the soil is heavy clay. Everyone in the street has the same problem.
Prior to laying my turf I brought the height up of my garden with 3 tonnes of top soil and sand. Under the flagged area I also put a soakaway in. I know now that soakaways do not work where the water table is too high - in this case because of the spring.
I was planning to install french drains to solve the waterlogged lawn issue leading to a sump and pump system under the flagged area, getting rid of the failed soakaway. I have a submersible water pump that I drop in a 3 ft hole that I dug. It shifts the water to the surface water drain in about 15 minutes but it is back to how it was an hour later. I have nowhere else to drain the water.
Any other suggestions or am I onto the right track? No pond. No bog garden as I have young kids. Any help would be greatly appreciated.
