i have built a metal shed to be used as a workshop with a foundation of edge mounted 8x2 joists for it to sit on.
It is sat on a concrete patio that has proved to be uneven with rain water run off ingress under the joists through a number of gaps where the ground dips away.
I'm looking for a waterproof expanding foam that will block this water ingress (which currently leaves a puddle in the middle of my workshop).
Are there any suggestions? I can't seem to find anything that is labelled waterPROOF only waterRESISTANT or weatherproof and I need something that won't absorb water and start to rot the timbers/introduce damp.
