Hello
I recently tiled a bathroom with some mosaic tiles. The problem is that the bath sits against a wall that steps out, so there is an area about 10cm x 1 metre along the edge of the bath that is flat and water pools there when the shower has run. The tiles are on WBP. We have been using a squeegy to ensure the water doesn't stand there, but the grouting is still getting discoloured and I'm having to regrout and reseal the area where the water pools a lot sooner and more frequently than I expected. I think water is obviously penetrating the (waterproof) grouting and the ply is expanding and staining through the grout.
It's not really viable to have the flat part remade a steep angle as it would look awful and also would remove space around the bath for stuff like shampoo, etc. I was wondering if there are any products that I could use instead - take up the mosaic tiles on the flat part, and pour in some sort of waterproof resin or screed and have that form a seamless joint to the bath edge? I was thinking in the same way as a resin floor. White would be good, or a light grey, but I would want a product that would have a consistent colour through it, and not look like unfinished concrete.
I thought about using a waterproof matting also, but I enivisage issues of how the membrane ends (it would have to overlap the lip of the bath edge, so I can't see that working).
Any suggestions / ideas on how to make a completely tanked solution, that is flat (or a tiny gradient, but still appears flat) for the sound of the bath would be really gratfully appreciated.
if it helps, I can take some photos and post that.
