Good morning,
Can anyone advise on and/or provide sections for the make up of a waterproof timber frame wall? If it's even possible of course!
Short version: need to build a flood resistant wall that currently divides a garage and a room with staircase (originally this room was the second garage). The existing wall is timber frame and currently stripped bare due to said flooding. Plan initially was to rebuild in masonry and then waterproof but that is likely going to require digging out footings and will result in a loss of space for insulation on top of thickness of masonry wall rather than 'within it' with timber frame. We will of course sacrifice and do this if necessary to prevent future flooding but would like to consider all options, including novel, first - after all, you can make a bathroom/wet room/swimming pool waterproof!
Chartered Surveyor who generated the schedule of works for reinstatement understandably requires 15mm Fireline plasterboard on the garage side of the wall so we understand that we need to provide that level of protection.
Things I've thought of so far as possible options (and I'm by no means qualified so these may be nonsense!):
- Board out with Fireline as required, and then skimmed with waterproof concrete based render and painted
- As above but boarding out with cement based board ('Hardie backer' type stuff?) - from memory this may provide the same level of fire rating?
- Boarding out with either of the above and then tiling with waterproof adhesive and grout
- Boarding out with either of the above and then cladding to the potentially highest waterline with either:
- Waterproof concrete based cladding
- Sheets of plastic such as Perspex, with joints and edges silicone sealed
- Sheets of tempered glass (such as that used for splash backs) with joints and edges silicone sealed
Most important thing is that the wall will need to keep out water for a period of submersion of let's say half a day and, if actually required to keep out the water, can just be jet washed down once waters have receded and ideally without having to replace any component. It feels to me like the most vulnerable points will be where any finish meets the floor, existing walls and any joints.
Is this pie in the sky thinking or might there be an option for this? Any thoughts gratefully received!
