waterproof window frame (tray)
8 Mar 2009
London
hello,
my name is Ric - am a newbie
want to make a (single glazed) window-type tray for holding water for a craft project - so the (interior frame) wood must be 100% waterproof and the glass-wood interface absolutely sealed. i have read on this forum about linseed oil paint, but is there anything else for sealing joints against moisture and for waterproofing frames please?
many thanks
R
if i understand your question correctly look here.
ABsealants.co.uk/WaterproofSealants
thanks Alastair - that looks excellent - had considered actually going out and buying a single sealed window unit but that would probably create more problems than it solved, with the double glazing (no use to me) and the frame construction :eek:
making my own will be more fun anyway :)
many thanks again
Ric
water based acrylic .........it says so in the data sheet in the link....... :eek: ;)
many thanks :)
just listing all the acrylic things i must put down first before i consider oil-based coats
will update
thanks again
R
