You could use an excel spread sheet to calculate offsets from centre for a sine wave. Plot all the dots and then join them up by hand.
If you decide on the
length of the half cycle(Distance between centre line crossings) and the
height you want each curve to reach (from the centre line to the peak) you could do the following.
In cell A1 you would enter the value of how far apart you want your dots.
In cell A2 enter double that value.
Subtituting the actual values for your Length and height
In cell A2 enter the forumula =SIN(PI()*A1/length)*height
Highlight Cells A1 and A2 and drag them down so that you have enough values for the entire length of the curve.
Drag down the forumula in A2 alongside.
Column A now shows distance from the start of the curve
Column B shows the offset from the centre line.
Draw a central line on your wall, and plot all the points!
God, I really must get a life
