I know there is already plenty of advice online about removing excess adhesive, so sorry about starting new thread. But this problem has given me hours and hours of work with little results so all advice appreciated. When putting up shiny 25mm mesh backed mosaic tiles in my shower area I couldn't avoid adhesive coming trough the cracks between mosaics in certain areas. Some areas look OK, but the worst areas look like the picture number 1 below.
I know that common advice tells you to remove excess adhesive when it is still wet, but when I did the mosaic tiles started to shift under my pressure so I had to leave it to dry instead. The day after, spending hours of scrubbing and scraping with undiluted FILA Grout Residue remover the best I could manage is the result you see in picture 2 below. Relatively clean grooves, but plenty of residue on the tile surfaces.
Two questions:
1) What is the toughest remover in the market? I could really do with something with a bit more bite than the FILA stuff. I have read about Cement Away, will that make a difference? And if I use stuff this strong, should I worry about the stuff loosening the bond of the tiles themselves? Also, will the tiles tolerate something as tough as steel wool?
2) What do you think of this strategy:
I am worried about adhesive seeping into the groves and behind tiles. And I am also worried that my scrubbing too hard before the grout is in will make the tiles come off. I am therefore thinking I should grout when the tiles are as in picture number 2. That is, clean grooves but with stained surfaces. Then I will scrub off both grout and surface adhesive when the grout has dried.
PICTURE 1
View media item 48012
PICTURE 2
View media item 48013
Two questions:
PICTURE 1
PICTURE 2
