Use this RichTee, they're easy to use.
https://www.tlc-direct.co.uk/Products/ASJ501.html
Though what you have posted are fine too, I think Tool station do Wagos in smaller packs https://www.toolstation.com/search?q=wago connectors
We haven't been told exactly what "in the ceiling" means in the OP's case.Only J803 and J804 are MF, that above needs to be accessible, so no good for the OP
Sorry Chivers
Sorry Chivers
Acceptable through a hole, yes thats what there designed for and were called downlighter boxes or something, however the op said in post 1 it was NOT accessibleWe haven't been told exactly what "in the ceiling" means in the OP's case.
What if a JB such as the ('non-MF') J501 illustrated by Chivers were 'accessible' through the hole accommodating a downlight (obviously after removing the downlight ). Would you consider that to be 'compliant'?
Kind Regards, John
Yes, I realise that's what he wrote, but I wasn't sure whether he realised that 'accessible through a hole' (after removal of the downlight) would probably count as 'accessible'.Acceptable through a hole, yes thats what there designed for and were called downlighter boxes or something, however the op said in post 1 it was NOT accessible
