Good morning - hope someone can assist!
Recently the above (which is under 2 yrs) has been recording an incorrect room temp of 23 degrees - infact, its stuck at this reading. Unfortunately, this means that the boiler (greenstar 30 cdi?) Doesn't kick in. The only way to get heat is to urn the stat up to 30!
Rang WB this morning who were no help (no disrepect intended) told me that's what extended warranties are for!!
My query is:
A. Is it dead (they seem to think so)
B. Is it worth replacing with the same model(not inclined)
C. Is there another model which is compatible with the boiler - any recommended models)
D. Should I go back to the mechanical equvalent - any recommendations
I'm so mad as I'm trying to make the house warmer, more economical to run before the big freeze kicks in.
Of the gentler persuassion (not being sexist and apologies for anyone's perception), just want some plain, simple advice.
Regards in advance.
My query is:
Regards in advance.
