Hi all,
I'm replacing our toilet in a 1930s building, the old clay waste (standard 110) is held in the cast iron soil pipe opening with tons of resin (inside dia. of cast iron opening looks around 140mm).
Should I avoid taking out the old resin and instead angle grind the clay pipe off? Would a standard pan connector fit into the inside of the clay pipe?
My connector could probably fit into 97mm dia.)
Anything else I'm not considering?
Thanks in advance!
Thanks in advance!
