WD 105 T knob keeps turning and not spinning
5 Aug 2006
Knob keeps turning problem I have read on manual and tried to cancel the program (stob/reset) as per the instruction but it won't work. Now I like to add something with you. In the ditargent drawer I have 3 pots. Water is comming to to the 1st pot at the beganing, then water draining out.. then knob started to turning and keeps going. I have changed the connection of the motor behind the water line from outside then water comes first in the 2nd pot.
Please help me.
I'm assuming this is an Indesit?
If it is, when the knob is turning the light should be flashing a code.
Count the flashes between pauses and post the result here.
