WD61 Filling with water when switched off
1 Jan 2006
Northamptonshire
This has gone from one extreme to the other, we were having filling problems--that were solved by "breezer"--a top bloke listen to his advice.
Now we have the opposite, the machine washes all ok, spins and pumps out fine. Then very slowly about 1 litre in 12 hours the drum will fill with clean cold water. I have checked to make sure the outlet pipe is OK and its definitely clean water filling the drum.
Any ideas gratefully received.
Jamie
its your fill valve (one of them)
its not shutting properly, easiest way is to change it
to find out if its the hot one or cold 2 try this
turn only one off at the fill hose connection tap over night.
if water in drum its the one that you didnt turn off that letting water by.
valves are here
other suppliers are available
