Good evening help please.
Went to turn heating on after the summer. The hot water is fine boiler fires up. But mo heating. Make a clinking noise from boiler.
The boiler makes a clikling noise as well? The switch on the wall doesn't click when you turn on. Normally you hear a sound? Please anything else would be really helpful. We both have health issues.
Do you have a thermostat ,is it calling for heat ?
If you have a programmer is it set to call for central heating ?
I have no idea what you mean by " filling up a water cylinder " ???
Sorry the water was low in the water cylinder in airing cuboard. And thermostat does not switch on heating. You normally hear it. We hear nothing at all.
Can you show us a picture of this water cylinder ,any motorised valves on the central heating pipes (usually found near the hot water cyclinder),the thermostat and the programmer or timer that you use to control the boiler.
