At the highest point in my house, I have one hot radiator that needs bleeding weekly if not daily and at the lowest part of my house I have a radiator that gets lukewarm at best. All other rads work fine.
I have a conventional CH system installed in 1985 which is not combi and has a hot water cylinder and expansion tank i.e. it is not directly mains fed.
In the spring, my plumber drained, flushed, refilled then balanced the system to get rid of cold spots.
I wonder if there is a connection between the need to bleed the higest radiator whilst the lowest is lukewarm at best ?
Is there any kind of treatment / gunge that I could safely put in my system (how, using a syringe in the bleed screw hole ?) that might seal the "bleed-needing" radiator as the plumber was not able to fix it, but charged me.
