Our old stone house has a recent extension, which is cavity construction. One wall faces SW and gets hammered by the prevailing weather. We arrived several years after the extension built and all that time one window on the exposed wall has damp on the reveals inside.
I have been at a loss to understand what is happening. But now I am certain it's because there are no weep holes above the lintel and penetrating rain is finding nowhere to go but over the cavity tray and into the reveals.
So what is the solution?
The stonework is irregular, to look like a rubble wall. I am thinking to hack out enough stones to see inside what is happening. Then fit the plastic type weep holes.
If the extension is about 15 years old, should I find stop ends on the tray? Can they be reinstated if not there?
Finally, I don't quite understand how the usual plastic weep holes work to remove any moisture.
Thanks.
Thanks.
