The cold feed to my combi boiler is weeping where the isolator valve meets the cast brass inlet manifold bit.
Its a flange fitting with fibre washer and it appears the due to possition of the plate the holds all the inlet/outlet valves the valve is not meeting with the cast manifold quite straight pushing the washer to the limit of what it will take up, and then Ive disterbed it prepairing the wall for the plaster to sort out the mess in the cupboard the boilers in.
Ive had it to bits, and put it back together and unsuprisingly its not slightly worse (drips about twice a minute not once a minute) so it needs a new washer.
Question is:
- Am I going to find a suitable wash in BnQ this evening after I get out of work.
- Given its on the ****, how likely is to to take up and last without rephasing the lot.
Daniel
Question is:
Daniel
