weeping shower
23 Apr 2011
Derbyshire
hiya all, i have a mixer shower - about a year or so old now been perfect but i noticed a tiny bit of green stain on of the the connections to the cold pipe (hot and cold pipe run down the wall) seems a tiny weep every fair few hours. rather than nipping it up which im guessing is the right thing??? also which way?? (is it just a olive that connectors on to the pipe and a elbow on to the shower unit
a bit like
http://www.bps-direct.com/shop/index.php?main_page=popup_image&pID=168
i wiped around it with some lsx as its the tinyist of weeps as its took a year and a half to even go green. will this sort it?
thanks
As you said, nip it a bit. Clockwise as the pipe enters.
how much do i nip it up?? thats why i put some lsx around it?? will this hold, i get scared.. is it just a olive that is bititing in to the pipe??
(PIPES GOING DOWN THE WALL)
l l
l l
I I-----------WEEPING FROM A NUT ABOUT EVERY DAY A TINY BIT
SHOWER
Try about an eighth of a turn - maybe even less. And yes, most likely an olive -water weeping aroun the edge of it, so a tiny fraction is unlikely to create a problem.
thankyou for your help, i guess as its been over a year and not caused a problem i shouldnt even be worrying about it, (but i do)
as it can be a day before i get a tiny weep the lsx should be up to the job, if not ill tighten it up clock wise a tiny bit,\
thank you! :)
