Two issues and I have had this system installed now for 18 months...
If it is set for a night set back room temperature of for instance 13C and the actual temperature is 18C and it never falls below that - when it is cold outdoors in can sometimes fire up the boiler quite briefly. This usually happens in winter, never summer. It has an outdoor sensor, might that have something to do with it?
If I have the night setback set at 13C day temperature 18C and override either of those temperatures by turning its knob to a higher temperature, it gives a choice of pressing OK to make the new temperature permanent, or not pressing OK which I assume should have it go back to the programmed temperatures, once the present heating period ends. It doesn't say when it should go back to normal programmed temperatures in the manual, I have assumed that it ought to work that way.
Except it doesn't - Change the desired temperature, don't press OK and often it makes the new temperature its permanent temperature until I spot it and change the desired temperature back again.
