hi, wondered if anybody could clear these questions up for me.
1, have a welding set at work which on the plate says 415v, 114A supply current.
does this 114A refer to total amps, i.e it'l be 38 per phase? or is it 14A per phase?
2, with 3 phase is this how it works where the equipment will pull equal amps down each phase roughly? or is there any flow of current between phases?
3, the circuit supplying the socket to plug into is protected by a 60 amp circuit breakers with 6mm live's, isnt this cable a bit undersized?
