Folks looks like I am about to embark on rendering then wet dashing my block workshop.
A few questions for those with the knowledge.
The base coat, what mix? sand/lime/cement
What is the common method for rendering base coat application. I am thinking of fixing any corner beads etc, apply and level vertical strips and let harder, throw the render and level with a wood strip, when dry (how dry? next day or day or so?) damp surface and harl wet dash.
Wet dash. What do I specify for the grit (peas?) is there a name or size I need to ask for, the existing finish looks like small sharp basalt (grey) stones about 3-4mm average.
What is the quantity calculation (5mm base?) (how much grit do I need to order say for 36sqm) and the mix ratio for a wet dash ?
