Hey folks,
was in the loft to sort some stuff and looks like I have a leak.
It's a 25 yr old semi with usual modern tiled roof.
Weird setup though - from the inside I can see it has joists as normal, but on the outside of the joists is a layer of gyproc board (ie outside of house side of joists, so from in the loft you can see the joist then the gyproc above it). Then a layer of felt then the tiles.
The gyproc half way down one side is damp on the inside (large area spanning maybe 3 metres length) with some mould. When it rained yestereday I could see the drips coming off the edge of the gyproc which sits over the edge of the outside wall in the soffit. So guess the felt is leaking, soaking the gyproc but running down it, which saves my bedroom getting wet!
There's no tiles missing, no chimney or vents or anything through the roof anywhere on that side of the roof. Not sure where it could be leaking. (Fairly sure its not condensation- there are brick vents in the side wall and vents all away along the soffit..)
Should I cut away the wet gyproc from the inside to see where its leaking from? My worry is that if I do that and don't find the point of entry and then it rains the water won't run down the gyproc anymore (cos it won't be there) and will come in the bedroom... or I might damage the felt cutting away the gyproc?
Is it generally easy to spot where water is coming through the felt?
Will probably try and get a roofer before xmas, but thought it might be worth investigating a bit from the inside...
Any advice folks??
Cheers, Andy.
Any advice folks??
Cheers, Andy.
