Wet room flooring advice
5 Sep 2007
Hi, I am about to start buying material for a wet room. The room will be on the second floor. I have lifted the flooring and now have just the joists. I was going to go with 18mm Marine ply and then overlay this with 6mm tile backer board. I was then going to tank the whole area including the shower tray. Is this the way to go?
There's much more to it than mentioned in your post - why not research the masses of threads on here and perhaps start with Similar Threads below?
heres quite a handy goto brochure from PCS (the makers of the Delta range of Wetroom and Tile Backer Boards)
Delta Wetroom Brochure
there are quiet a few different types of tray available and some fitting instructions are on the link above
there is also a youtube installation video
