Not sure if this is the right forum but here goes.
We recently moved into a concrete floored bungalow, and i'm hoping to convert the en suite bog into a wet room shower area.
The room will need enlarged but this is no problem, i can steel the space from a hallway cupboard and a built in wardrobe on the main bedroom. So loads of room - but a concrete floor.
I know concrete floors are "do-able" but i'm not sure what exactly is involved. At the minute there is a toilet where the waste goes down through the concrete floor to the drain outside. And a basin where the waste runs along the wall above ground and on outside into a drain.
Is there any way the future shower drain can tie into the toilet waste pipe below ground?
