Wet room waste
I'd be inclined to check that the waste you're planning to fit is compatable with the type of flooring you are using.
Given that if the waste /floor seal breaks down then you will have a significant problem check .... check and then check again!
Wet rooms ? take a look at the Marmox , showerlay wet room flooring system , includes preformed tray area with built in falls , ready for tiles !
