wet room
6 Aug 2009
West Midlands
does a wetroom have to be tanked before it is tiled or can you just tile the walls and floor and silicone the internals and perimiters
if the wetroom is in a cellar/basement(no rooms underneath)..and the walls are concrete,then yes you could not tank out....BUT thats YOUR call.
if wetroom has adjoing rooms and underneath,then YES tank it with the correct prep/materials..etc..
if you are converting to a wet room, you have to tank it first otherwise you will end up with major issues.
