Hi
We have a garden shed which was here before we moved in. How it was built I don't know as it is in a 5 foot gap between the house and the fence between the properties. It is only about 2 inches from the outside wall of the house and butted up against the fence posts on the other side. This makes it impossible to access at either side.
There is a problem with water getting into the shed. First of all I could see it getting in via the roof so I've used some paint on sealant which seems to have fixed this (for now).
Unfortunately there seems to be water getting directly onto the floor somehow. I believe it may be because the side wall of the shed is butted against the fence posts and water may be running down the posts and in under any gaps between the wall and the floor. Maybe ??
As I mentioned it's not possible to acces the sides of the shed but I'd rather not let the thing rot as I've no idea how I'd get a new one in the gap that's there !!
Would running caulk or some other sealant along the inside of the shed at the floor/wall joint make a difference or would this just possibly cause more problems down the line ?
