Photos:
https://imgur.com/gallery/Vld7A
Hi, we purchased a new house and we knew it would have some issues.
1930 concrete block 215mm thick with render construction. Timber suspended floors on concrete piers in a sub floor.
There is a cracked concrete path that runs down the side of the house, it's higher than the floor level and as such we were expecting rotten timbers on that side, surprisingly timbers are better than expected for the sub floor.
However the sub wall on the path side is a bit damp, and I'm wondering if I should try to improve that situation?
The chimney breasts extended into the sub floor, and look like they were once open to vent the sub floor, but have been bricked up, should I open those back up?
Sub floor vents, 2 front, 2 rear were partially open, but I've stripped back about ten layers of paint to open up the grooves.
I was going to lower the side path, but we have a neighbouring retaining wall and I don't think I can lower the path significantly.
Instead I was considering building an open lean-to and getting the concrete off to try and keep it dry.
Or should I excavate down the wall and put in a French drain?
I'll add a photo of the side path
