Wet Tile Saw Cutting Issues
17 Jul 2014
London
Evening all
I've been experiencing my saw not cutting in straight lines today for some odd reason
It's a wickes/plasplug 550w run of the mill type with a newish bosch blade sharpened
Tiles I've been cutting are normal wickes branded 60x30, cutting lengthways
What I'm experiencing is the blade wanting to 'wander' to the left, even when I'm rotating the tile slowly. Over the course of cutting the tile, the blade goes about 7mm out of line
Checked the disc, all straight, checked the motor, all good there
What else should I be looking for?
Many thanks
First thing I'd do is use a dial indicator to see if there's much run out on the blade.
Presuming you use the fence I'd check that, not for square with the bed but parallel to the blade.
I can't see that the blade will drift as there's very little wobble in those types of discs and if the motor was running out you'd probably hear the bearing rattle.
