Hi, hoping for a little guidance please.
I've an electric boiler, so obv with prices as they are looking to run things more efficiently coming up to winter here in the UK.
My programmer/timer is an old Honeywell ST699 (which ideally I'd look to replace in due course because I find it rather inflexible).
Looking at my plumbing, there's no 2-port valve coming off of the flow from the boiler to the UFH.
The actuators on the manifold open, per request from the independent room thermostats. And these remain open, regardless of whether the ST699 is on for CH or not, if the thermostats are set to a temp higher than room temp.
That's as I've observed everything so far.
However, the last few days I've noticed the hot water not being as hot from the taps.
The only thing I can think of that's changed is that I was experimenting with getting the thermostats set for the rooms as winter approaches, and therefore the actuators for those UFH zones are open. Before now, the rooom thermostats (old Rehau dial thermostats have been set to the * position - the lowest on the dial).
SO, at present I am NOT using the CH timer on the ST699 to request underfloor heating.
As there's no 2-port on the flow to the UFH, does that:-
a) mean I'm not on a proper S plan etc. ?
b) mean that hot water is flowing through the UFH circuit regardless of whether or not the programmer is calling for CH, IF the one or all of the actuators are in the open position?
c) that because the actuators are open the larger heating circuit is reducing the heat exchange flowing to the HW storage cylinder in the time allowed by the programmer?
In other words, with no 2-port present on the UFH side of the system to close it off, is the HW side of the system being hindered?
I've seen videos where when explaining Y plan configs the narrator has suggested that CH be set on the timer to a period separate to the HW so as to maximise the heat to one system or the other, so I'm just clutching at the idea that maybe the way my CHS has been plumbed in isn't as efficient as it could be.
Tomorrow, I'm going to turn all the room thermostats back down, so all the actuators are closed again, and after the HW has been on just touch test the flow of hot water to guage it's temp.
However, aside from that, I'm really wondering if longer-term I ought to have a 2-port valve present, and ought to start saving to get a plumber out in the new year.
Thanks for any pointers.
