I am planning to fit single room ufh in my extension - problem is the 100mm celotex is already under 50mm concrete slab - if I screw down the pex pipe using copper 2 hole pipe clips directly onto the slab and lay 50mm screed on top will the ufh heat the room (knowing that I will have some downward heat loss until it hits the celotex) I’m aware of the overlay boards but trying to keep the cost down and the boards would be £400
